janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
Jul 01, 2015Guru - Experienced User
The bit rot protection is a differentiating feature of Netgear's, so the available details are a bit sketchy. But I think you are correct that the checksum is needed for it to work.
janpeter wrote: 1a) I guess you must enable check sum on the volume in order to later be able to enable bit-rot protection etc for folders, right? Or do I misunderstand the role of the check sum function?
Of course it is an extra step, and it needs to be computed/saved for every disk write. I have it enabled on my RN202, and have not seen any obvious slowdown. Of course if you want best performance you could get a RN516. That also provides error correcting RAM (ECC).
janpeter wrote: 1b) Does this enabling of the check sum of the volume slow down even if I do not user bit-rot protection at all, or only for smaller part of the volume, and then I mean the performance of the not bit-rot protected part?
First - it is always cheaper to expand the NAS later on if you have an empty slot. For instance, if you have an RN312 with 2x4TB disks, then increasing the capacity to 6 TB requires you to buy two new replacement drives( $500 US at the moment), and stop using the old ones. If you have an RN314 (or an RN316) with empty slots, then you can get grow from 4 TB to 8 TB by adding a single 4 TB drive to the array ($160 US at the moment).
janpeter wrote: 7) I try to find arguments for when 2 separate volumes may be a good idea. Then a 4-bays system makes additional value to me. Or you would say the main argument is raid5 and less redundancy and you more “effectively” use your disks.
So in this example the RN312 upgrade costs $250 per added TB, while the RN314 upgrade (with an empty slot) would only cost $40 per added TB.
Second - having 4 or more slots available lets you use some of the more advanced RAID modes. These modes don't increase storage efficiency, but they have other advantages. RAID-6 provides dual-redundancy (survives all combinations of 2 disk failures) and RAID-10 (better performance than RAID-6; survives some combinations of two disk failures but not all).
But to get to your question - Using two RAID-1 volumes lowers capacity, but recovery of data if the array fails is generally easier, because the mirroring allows each drive to be independently mounted. Writing to RAID-1 is also somewhat faster than writing to RAID-5.
Also if you are considering RAID-0, having one volume per disk is much more reliable than creating a single RAID-0 volume that spans multiple disks. If any disk in the RAID-0 array fails, the entire volume is lost. So if you want maximum capacity in an RN312, I recommend having 2 volumes (and would recommend 4 in the RN314).
Keep in mind that RAID is not a form of backup. It will keep your data available through "routine" disk failures and it allows you to expand your storage while keeping your data on-line - both of which are great. But RAID arrays can fail, and there are other system failures (and of course disasters) that result in data loss. So you should invest in a backup solution as part of the purchase.
