janpeter1
Jun 27, 2015Luminary
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
- Aug 04, 2015
You could put a suggestion in the Feature Request & Feedback subforum.
You could also make a request at rnxtras.com (not a netgear site)
Jul 04, 2015Guru - Experienced User
Some high-end workstations support ECC memory, though generally it is a server feature. It does cost more, so Netgear choose to use it only on the high-end NAS. So you'd need an RN516 to get it (RN700 has it as well).
janpeter wrote:
1) So little incentive for small office home to invest in ECC memory I guess?
I work in the life science sector and people working with databases for genetic material etc
are usually very keen to ensure ECC memory and often use ZFS systems.
But I have not much of this kind of data on my desk.
You can do this. We are just saying that iSCSI isn't the way we would do it. You can set up Plex to access the media even if it is in a normal share. Just mount the share on the mini.
janpeter wrote: 2) iSCSI - can you sketch roughly what the main problem is with letting an aged Mac mini
stand for the CPU-power and ReadyNAS 3-series for the storage of media using Plex?
Much better to let ReadyNAS be the Plex-server in a stand alone way?
FWIW Plex on my RN200 works quite well, and can transcode 720p acceptably. I suspect the 300 would be at least that good, though the 500 would be better still (giving you a second reason to go for it).
