pwozney
Oct 31, 2006Aspirant
Local unrar
I would like an option to locally unrar/zip something, because when compressed files are stored on the NAS they must be copied back to my server for decompression. This is okay for small files, or ...
Zappes
Aug 14, 2008Aspirant
The ReadyNAS has a SPARC CPU, you installed a binary for Intel x86. This has no chance of working, remove the binary and use the apt-get approach described by chirpa instead.
(You will need the APT-add-on for that).
