pwozney
Oct 31, 2006Aspirant
Local unrar
I would like an option to locally unrar/zip something, because when compressed files are stored on the NAS they must be copied back to my server for decompression. This is okay for small files, or ...
chicken
Aug 17, 2008Aspirant
Thank you Zappes,
Initially I did try this, and on attempting "apt-get install unrar", I received the following;
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
unrar: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
Depends: libgcc1 (>= 1:4.1.1-12) but 1:3.4.3-13 is to be installed
Depends: libstdc++6 (>= 4.1.1-12) but it is not installable
W: Couldn't stat source package list http://packages.debian.org readynas/ Packages (/var/lib/apt/lists/packages.debian.org_stable_utils_readynas_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I'm not confident enough to simply try the apt-get update and don't know much about all the C type stuff above.
The First two packages appear to be installed (see below), however the libstdc++6 is not.
readynas:/# dpkg -s libgcc1
Package: libgcc1
Status: install ok installed
Priority: required
Section: libs
Installed-Size: 152
Maintainer: Debian GCC maintainers <debian-gcc@lists.debian.org>
Source: gcc-3.4 (3.4.3-13)
Version: 1:3.4.3-13
Depends: libc6 (>= 2.3.2.ds1-21)
Description: GCC support library
Shared version of the support library, a library of internal subroutines
that GCC uses to overcome shortcomings of particular machines, or
special needs for some languages.
readynas:/# dpkg -s libstdc++6
Package `libstdc++6' is not installed and no info is available.
Any assistance in where to go from here will be appreciated. Thanks in advance.
Package: libgcc1
Priority: required
Section: libs
Installed-Size: 152
Version: 1:3.4.3-13
