pwozney
Oct 31, 2006Aspirant
Local unrar
I would like an option to locally unrar/zip something, because when compressed files are stored on the NAS they must be copied back to my server for decompression. This is okay for small files, or ...
Zappes
Aug 17, 2008Aspirant
Doing "apt-get update" will not hurt you - trying something like "apt-get upgrade" or "apt-get dist-upgrade" may be a bit of a problem, though, so better avoid those. ;)
I just did an apt-get update followed by apt-get install unrar and it works like a charm.
Edit: You might want to install the latest beta firmware, though - I don't know which kinds of dependencies might not be satisfied by the earlier versions as I use T136 on my box.
