icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello, I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0 ...
icyvran
Jun 15, 2014Tutor
I have a solution for my own question :D
In order to install the Logitech UE Music Library on a ReadyNAS with OS6 version 6.1.8 you have to:
Then you can access the server settings on http://192.168.1.8:3546/
Good luck! :)
- 1. Install and then uninstall the app "Logitech Media Server" that is available for OS6
2. Access the ReadyNAS via SSH
3. Install via SSH the "UE Music Library: Debian Installer Package " that is available in http://downloads.slimdevices.com/nightly/?ver=10.0
Good luck! :)
