icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello, I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0 ...
mrfusion
Jun 28, 2014Aspirant
Bought a UE smart Radio to someone of my family which has a readynas 102 using OS6.
unfortunately as icyvran told there is no direct package for OS6.
icyvran can you detail your installation process because I don't understand why you first install/uninstall LMS?
Is it to ensure to have the dependencies installed?
I guess you installed the package with dpkg -i ?
To Superpoussin: that would be wonderful to do the package for OS6 as it is the only one missing.
I installed the package available on the link on my duo to test the smart radio and it was working great.
