icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello, I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0 ...
markwoll
Oct 09, 2014Guide
smallsings wrote: Hello,
so i tried to install the "UE Music Library: Debian Installer Package" on my Readynas 314, but the installation process was not working.
is there a solution without having the ssh root stuff?
Did you install the lms_1.0.6_all.deb file?
I think that is a prereq for installing one of the deb files from the logitech repository.
May be wrong, but don't think it would hurt before trying the UE Music Library installer again.
Even though I use the LMS package, the above file seemed to take a while before it installed, on a 516.
