icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello, I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0 ...
smallsings
Oct 10, 2014Aspirant
Okay before i tell what it did: at my Readynas it WORKED!
Thanks markwoll!
I have Firmware 6.1.9
I installed the Logitech Media Server in the app section.
After installing I deinstalled it and manually installed "UE Music Library: Debian Installer Package".
It takes a while and first it said that installation failed....but a second try my Readynas said it was successfully installed.
So just wait a bit like markwoll said.
The App is not shwon in the installed apps section.
But with putting the portnumber ":3546/" behind the IP of your Readynas you have the server!
Perfect!
Here a screenshot of the Log:
Thanks markwoll!
Perfect!
