icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello, I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0 ...
nsne
May 27, 2015Virtuoso
UE media server is no longer installing for me. I'm running 6.2.4 — it stopped working somewhere around the 6.2 iterations. I've tried all the suggested steps (installing LMS, then uninstalling; installing LMS, then installing UE; etc.) and nothing works.
Would someone be so kind as to make a ReadyNAS app out of the latest version of the UE Music Library (available here) so those of us running a UE device can access our music?
- icyvranJul 21, 2015Tutor
Hi,
I got it working again on ReadyNAS OS 6.2.4. This is what I did:
Using the manual installation of the deb files. You can read a tutorial here: https://rnxtras.com/add-on-installation/add-onapp-installation-on-readynas-os-6-arm-x86
First I installed the lms_1.0.8_all.deb from:
It will fail, but it doesn't matter.
Then I installed UE Music Library Debian Installer Package from: http://downloads.slimdevices.com/nightly/?ver=10.0
