Flussig29
Sep 29, 2020Aspirant
Looking for a 8 Bay ReadyNAS
Hi there Is there a problem with supply for the 8 Bay ReadyNAS units? I can't seem to find them in stock in the UK. There is also a lack of 8 bay units on ebay which seems odd. Can someone list...
- Oct 01, 2020
Manufacture of the units have been greatly affected by the pandemic add to it the distribution delay depending on what Country or region it will go. Hopefully everything gets back to normal.
I agree with what Sandshark mentioned regarding units with high demand are going out first.
HTH
Flussig29
I'm in the UK so won't order from CDW. It does feel like the 8 bay design has been dropped given the lack of units available.
Sep 29, 2020Guru - Experienced User
Amazon UK does have a couple RN628x in stock.
- Flussig29Sep 29, 2020Aspirant
I saw those but not sure sellers are genuine, some selling for £222 for a 8 Bay doesn't seem right
- SandsharkSep 30, 2020Sensei
The 8-bay units probably have the smallest demand other than rack mount. There has been a shortage of supply of all units, which is changing. Some have speculated it's because Netgear is going to replace or abandon them, but StephenB and I suspect it's more COVID-19 colliding with the "just in time" supply chain that most manufacturers use. Even if Netgear's manufacturing wasn't affected (and I'm sure it was), their supply chain definately would be. And those products with least demand are undoubtedly going to be the last ones they get moving again. I don't know if the ReadyNAS lines share production assets that may be going to more popular product lines like routers and switches. Even simple transportation has been affected by COVID, with priority going to certain essential product groups.
- Flussig29Sep 30, 2020Aspirant
agreed, time will tell whether it's covid related or the dropping of lines.
