flazer's avatar
flazer
Looking for a NAS box for Mom
Hey all,
Mom has a desktop and a laptop I'm looking for a box that might both her and my life easier!
Easier for me cuz right now, i'm battling a nasty virus on her laptop and it sure would be easier to joust blow out he OS and restore from a backup - if she had one.
Recommendation?
I like my RND2110 and have two drives in it but really think for her that's overkill...
thanks and, looking forward to your replies! :)
  • StephenB's avatar
    PapaBear wrote:
    StephenB - I disagree slightly about the performance gain of the Ultra over the Duo, it is not just very noticeable it is night and day!
    Yes, I was being too understated. :D After a couple months with the pro, it would be very painful to back to the duo as my main NAS.
  • flazer wrote:
    maxblack wrote:
    I dunno flazer, I think you're making a mistake here. After all, it's been said many times "you gotta backup your NAS" i.e. it could fail as well, and in the end you have to buy something to back IT up so...
    Appreciate your reply as well; however, not sure where you are headed here... If your box is a primary repository then yes, makes sense to have a second backup plan, But (as in this case), the box for mom would serve purely to back up: hard to see the need for yet anther box. After all, there would exists 3 copies for each of my mom's machines - the originals on each machine and the double copy in the NAS box (provided said box has 2+ physical drives).
    I don't disagree. However the "nightmare scenario" remains, which is a lightning strike/power hit that kills all 3 at once. It happens.
    I like removable drives for backups of irreplaceable data--connect, back-up, disconnect, store somewhere safe. I like NAS for sharing common files across a multi-PC network 24/7, and yes it allows easy backup of networked PC files on-the-fly.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I agree that offsite backup of irreplaceable data is a good idea. Depending how much irreplaceable data your Mum has using something like the free version of Dropbox might be sufficient for that, whilst still using the NAS to backup everything.
ProSupport for Business
