alokeprasad
Jan 05, 2018Mentor
looking for advice on drives for Duo v1
I found the HCL list for legacy devices https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List Those specific drive models are either not available, or available used or at very high...
Jan 05, 2018Guru - Experienced User
I use a WD20EFRX myself, though I'm sure a 2 TB Ironwolf would also work.
I don't recommend using desktop drives in NAS anymore, as I think NAS-purpose drives are better choices.
FWIW, I do have my duo set up with two 2TB volumes in order to maximize it's capacity. I am only using it as a tertiary backup, so I don't need RAID redundancy.
- alokeprasadJan 05, 2018Mentor
You chose newer "red" WD drive over ones in the offical compat list (from way back when). I will end up doing the same after I get a new NAS installed and relegate the Duo as a backup to that NAS.
In the mean time.. I'll keep watch on SMART errors from both of my legacy Barracudas (one old, one purchased yesterday to replace my Disk 2).
- StephenBJan 05, 2018Guru - Experienced User
Yes. The problem is that the list is from "way back when", and hasn't been updated for years. I see no reason to track down obsolete disks (and then paying a premium price to get them).
