pimpyoda
Oct 06, 2020Aspirant
Looking for R-Studio RAID Parameters for NV+
Does anyone know the correct RAID parameters for a ReadyNAS NV+? I am trying to do data recovery using R-Studio. I was told in a previous thread that NV+ uses RAID 4. However, there are still a f...
Oct 07, 2020Guru - Experienced User
R-studio should be detecting them automatically. Are you saying that isn't working?
- pimpyodaOct 07, 2020Aspirant
They said the autodetect feature only works for RAID 5 and 6. I ran it anyways just to check and it got to about 43% and just sat there for over a day.
- StephenBOct 07, 2020Guru - Experienced User
There is also a free utility from ReclaiMe that might be able to figure it out. http://www.freeraidrecovery.com/
Though R-Studio support really ought to know this, since there product has been used to recover files from legacy ReadyNAS.
That is a bad sign. Have you tried running the long disk test using vendor tools (Seatools for Seagate, Lifeguard for Western Digital)?
