Adam2696
Jun 30, 2021Aspirant
Lost access to Readynas 214 via https
Problem: So, I lost access to my readynas 214. I can not mount the drive or access it from https:\\192.168.1.XXX. History: Recently factory reset device after power outage (February - March)....
- Jul 01, 2021
Adam2696 wrote:
Ok just checked the actual device and it is saying
out_of_memory+1dc
So it crashed at that point. You'll need to forcibly power it down, and then power it up again.
The massive deletion processing is likely part of the puzzle, but it would be good to reduce the memory footprint of the NAS if you can.
File search and AntiVirus take a lot of resources, so if you don't actually need those services it would be good to disable them. Maybe also look at system->settings->services, and see if there are any you don't actually use. You can follow up here if you aren't sure.
What apps are you running?
Adam2696
Jul 01, 2021Aspirant
out_of_memory+1d c
this is exactly how it says it
Jul 01, 2021Guru - Experienced User
out_of_memory+1dc
