nicho2014
Jan 14, 2014Aspirant
lost volume after replace disk in Pro Pioneer Edition
After I replace a broken disk in the Pro Pioneer Edition, I lost volumes and got two alert emails. How can I recover the volumes? Thanks, Nicho 1. first alert email: ***** File system ch...
vandermerwe
Jan 14, 2014Master
What alerts did you get before you replaced the disk?
Were there any problems with the other disks before this happened (smart errors)?
How many disks are in the NAS?
Were you using xraid?
What happened after you replaced the broken disk and are you certain that you replaced the correct disk?
Do you have a backup?
Have you logged a support request? even if the unit is not under warranty they may help you for a fee.
