rhpot1991
May 25, 2021Guide
Low Battery Warnings (6.10.5)
After upgrade to 6.10.5 my NAS is throwing low battery warnings randomly throughout the day. Then all my other NAS that use this UPS remote pick up the warning, spamming my email box. Battery is fi...
Sandshark
May 25, 2021Sensei
rhpot1991 wrote:Battery is fine, everything is running on power.
And you know the battery is fine how? The usual cause for this is that the UPS is reporting a low battery, whether or not it really is, not something within the NAS. Most UPS will continue to power the attached devices fine with a bad battery as long as the power stays on.
rhpot1991
May 25, 2021Guide
Display on the UPC itself says full battery. I'll see if I can identify anything via command line, possibly move to another of my ReadyNAS to see if I get the same behavior there.
