rhpot1991
May 25, 2021Guide
Low Battery Warnings (6.10.5)
After upgrade to 6.10.5 my NAS is throwing low battery warnings randomly throughout the day. Then all my other NAS that use this UPS remote pick up the warning, spamming my email box. Battery is fi...
rhpot1991
May 25, 2021Guide
Display on the UPC itself says full battery. I'll see if I can identify anything via command line, possibly move to another of my ReadyNAS to see if I get the same behavior there.
Sandshark
May 25, 2021Sensei
Moving it to another NAS would be a good way to see if it's the NAS or the UPS. While the display says the battery is good, it could be sending out sporadic bad data on USB. If it is the NAS and you want to return it to that NAS, deleting the UPS and letting it be re-installed might help.
- rhpot1991May 25, 2021Guide
Delete and reinstall didn't help, I tried that before posting. I'll have to check to see if I still have a NAS on 6.10.4 that didn't take the upgrade yet.
- rhpot1991May 28, 2021Guide
I'm not sure what caused this, but I plugged the UPS into several other ReadyNas without issue. Plugged back into the original showing the warnings and it has been running without issues for over a day now.
- Michel-jacobsJul 11, 2022GuideIf I look at performance, ups it is stated that battery is 100% and time is 0 . This is on version 6.10.7. I reinstalled 6.10.5 but that states the same. Ran battery.deep.start from cli. Still no change...
Anybody ?
