2Compute
Feb 25, 2019Aspirant
Malware warning
RN422
Firware 6.9.5
Antivirus feb 24, 2019 14:23:00
Nas reports:
Antivirus scanner found a threat (Doc.Malware.Sagent-6865733-0) in the file .../409_Linzensoep.doc. Please delete the infected file soon.
Scanning with other antivirus product of related file(s) with product like Norton, Mc-Afee, Kasperky all report no mallware/virus.
Are these false positives as Symantec suggests? Which AV-software is used by Netgear. How to fix/remove both warning and mallware (if any)?
ClamAV.
You could report it at https://www.clamav.net/reports/fp
- tamthnguyenAspirant
Hi, I am getting the same virus warning to many of the word documents some of which has not been touched or modified for a few years. When I download and scan the file with AVAST antivirus, no virus was found?... Could this be a false possitive ?
Please advise .. anyone? ..
Thanks..Tam,
Likely yes, which is why I suggested reporting it to ClamAV.
- 2ComputeAspirant
FYI:
Already reported problem yesterday to ClamAV en uploaded one of the files. No reponse from ClamAv yet.
Date Antivirus meanwhile updated to feb 25 2019 11:48:17, but still the same warnings (always on MS-Word docs)
- GKCanadaAspirant
You guys (gals) are awesome, thank you for doing this and reporting it to others. I'm having the same reports and I'm sure the files are OK (but how can anyone be sure these days?).
Would love to hear what ClamAv responds with.
