KristianSnellin
Oct 12, 2017Aspirant
Management Service is offline (RN102)
ReadyNAS firmware 6.8.1 Hi, I have been using ReadyNAS for a while now, I have four in total and they have been 'almost' flawless. This morning, however, when I turned one of them on, the Powe...
- Oct 23, 2017
Hi All.
So the fix was, Reset to Factory Default. Which is not really a solution, but has had the desired effect, my Management Service is working fine.
Thanks to Stephen B for his guidance and confirmation in the process.
Top Tip: Keep a backup of your data and settings somewhere other than on your NAS box.
Red One - Out
Oct 16, 2017Guru - Experienced User
Open volume.log in the zip file, and scroll down to the section that has df -h
The first couple entries relate to the OS partition. Do any of those look full?
KristianSnellin
Oct 18, 2017Aspirant
Hi StephenB,
Output of Volume.log
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 604M 2.9G 17% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 564K 248M 1% /run
tmpfs 125M 796K 124M 1% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/md127 2.8T 2.3T 478G 83% /data
/dev/md127 2.8T 2.3T 478G 83% /home
/dev/md127 2.8T 2.3T 478G 83% /apps
tmpfs 50M 0 50M 0% /var/replicate/shm
So, in short, no, a full system partition appears not to be the issue...
Thanks.
- Jun 10, 2022Retired_Member
