KristianSnellin
Oct 12, 2017Aspirant
Management Service is offline (RN102)
ReadyNAS firmware 6.8.1 Hi, I have been using ReadyNAS for a while now, I have four in total and they have been 'almost' flawless. This morning, however, when I turned one of them on, the Powe...
- Oct 23, 2017
Hi All.
So the fix was, Reset to Factory Default. Which is not really a solution, but has had the desired effect, my Management Service is working fine.
Thanks to Stephen B for his guidance and confirmation in the process.
Top Tip: Keep a backup of your data and settings somewhere other than on your NAS box.
Red One - Out
KristianSnellin
Oct 18, 2017Aspirant
Hi StephenB,
Output of Volume.log
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 604M 2.9G 17% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 564K 248M 1% /run
tmpfs 125M 796K 124M 1% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/md127 2.8T 2.3T 478G 83% /data
/dev/md127 2.8T 2.3T 478G 83% /home
/dev/md127 2.8T 2.3T 478G 83% /apps
tmpfs 50M 0 50M 0% /var/replicate/shm
So, in short, no, a full system partition appears not to be the issue...
Thanks.
Oct 19, 2017Guru - Experienced User
Agreed. Does https://nas-ip-address/fwbroker respond?
- KristianSnellinOct 19, 2017AspirantNegative.
It just comes up with the loading page for a while which fails to find anything which then forwards me onto, have you turned it on, is there a network connection.. blah blah
😐- StephenBOct 19, 2017Guru - Experienced User
What apps did you have running?
Since your OS partition is healthy, you could try an OS reinstall from the boot menu. Just be careful not to do a factory default by mistake.
- KristianSnellinOct 19, 2017AspirantHi
I do not run any apps on that box, it is purely for DNLA use.
I came to the same conclusion. But thanks for the confirmation. I will do it over the weekend and report back. Yes, choosing the right option is paramount, but in meantime I am getting as much of the data elsewhere as I can. 👍🏻
Thanks for all your help thus far
Kristian
- Jun 10, 2022Retired_Member
