KristianSnellin
Oct 12, 2017Aspirant
Management Service is offline (RN102)
ReadyNAS firmware 6.8.1 Hi, I have been using ReadyNAS for a while now, I have four in total and they have been 'almost' flawless. This morning, however, when I turned one of them on, the Powe...
- Oct 23, 2017
Hi All.
So the fix was, Reset to Factory Default. Which is not really a solution, but has had the desired effect, my Management Service is working fine.
Thanks to Stephen B for his guidance and confirmation in the process.
Top Tip: Keep a backup of your data and settings somewhere other than on your NAS box.
Red One - Out
KristianSnellin
Oct 22, 2017Aspirant
Thanks for the confirmation.
Have found another 500GB drive that was attached to X-box (now reformatted NTFS) so have now copied the last few files to there and 100% checked I have everything - so biting bullet is the way forward now.
I will update once done. Fingers crossed
KristianSnellin
Oct 23, 2017Aspirant
Hi All.
Red One - Out
- Jun 10, 2022Retired_Member
