Mixster181
May 07, 2017Tutor
Management service is offline
I have updated my firmware to 6.7.1 Noticed that Plex was showing OFF Each time I tried to switch to ON it would give an error Decided to reboot Now I cannot access the Admin page and RAIDar s...
- May 08, 2017
This means your 4GB root volume is full. You could use the du command to find why it's full
e.g.
# mount --bind / /mnt # du -csh /mnt/*
Mixster181
May 11, 2017Tutor
I do now............thx again.
Only issue now is Plex App says it is off but I can access from devices on the lan.
When I try to turn it on it gives an error but seems to be working??
Have reinstated Plex app but no change.
claytonb
May 20, 2017Aspirant
I am having the same problem after Beta 6.7.3 - T283 update, keeps telling me to retry startup which I have done a few times. RaedyNAS 314
- mdgm-ntgrMay 21, 2017NETGEAR Employee Retired
Are you able to boot fine into volume read-only mode?
- claytonbMay 21, 2017Aspirant
Not sure how to do that,
I have booted into read only mode and it still says retry startup 91% and Management service is offline, should I try the OS Reinstall mode?
I can see you have rsyslog installed. Your logs for that have grown to be huge.
Can we delete them? not sure what that is !!
Hey thanks for whatever you did, I am backup and running now NETGEAR all the way for me!!
I emptied the rsyslog logs but after rebooting am now unable to get back in. I've diagnosed why the remote connection didn't work on 6.7.3 Beta 1 and reported that to engineering.
- claytonbMay 22, 2017Aspirant
Thanks, do I need Rsync enabled or can I disable it? is this causing rsyslog logs to grow huge?
How do I get out of Remote Support mode in Raidar?
- mdgm-ntgrMay 22, 2017NETGEAR Employee Retired
Rsync and rsyslog are two separate things. Rsyslog would have been put on the system by an app e.g. LogAnalyzer.
Are you comfortable with using SSH? I can't disable the Remote Support mode easily till you update to 6.7.3 Beta 2 (or later) once that's available.
Hi there, not familiar with SSH but have enabled it incase of any future issues that may arise from time to time.
Have you disabled Rsyslog so I won't have this problem in future.
I don't have any apps installed, mainly use the system to backup data from PC, FTP Server, ReadyCLOUD and ReadyDLNA
- claytonbMay 24, 2017Aspirant
Was good to get a email alert this morning from my NAS unit LOGMSG_FIRMWARE_UPDATE_NOTICE, this has never happenned before, I ran the update and it is still showing Remote Support, the 5 digit code is the same
- mdgm-ntgrMay 24, 2017NETGEAR Employee Retired
Secure Diagnostic Mode starting each boot should now be disabled.
We now prompt when a firmware update is available from our update server.
Thanks for all your help
- Jun 10, 2022Retired_Member
