Mixster181
May 07, 2017Tutor
Management service is offline
I have updated my firmware to 6.7.1 Noticed that Plex was showing OFF Each time I tried to switch to ON it would give an error Decided to reboot Now I cannot access the Admin page and RAIDar s...
- May 09, 2017
This means your 4GB root volume is full. You could use the du command to find why it's full
e.g.
# mount --bind / /mnt # du -csh /mnt/*
claytonb
May 23, 2017Aspirant
Hi there, not familiar with SSH but have enabled it incase of any future issues that may arise from time to time.
Have you disabled Rsyslog so I won't have this problem in future.
I don't have any apps installed, mainly use the system to backup data from PC, FTP Server, ReadyCLOUD and ReadyDLNA
claytonb
May 24, 2017Aspirant
Was good to get a email alert this morning from my NAS unit LOGMSG_FIRMWARE_UPDATE_NOTICE, this has never happenned before, I ran the update and it is still showing Remote Support, the 5 digit code is the same
- Jun 11, 2022Retired_Member
