rampa99's avatar
rampa99
manuel setup for phpmyadmin - step by step
Just thought it could be useful for some. A simple step by step "how to" to setup php & phpmyadmin on a readynas duo v2. Of course, you follow my instructions at your own risks, & i wont be responsible should your nas crash, bricks, become sentient or kill your cat.
0. starting point :
0.1 Matériel: Readnyas duo v2 up-to-date with both netgear photo modules (so mysql is up and running) and Photo II et SSLConnect activés,
0.2 Softs : PuTTy, Notepad++, Filezilla
0.3 Sources : Many thanks to kiokoman & loustik, whose ideas i just test and reordered.
0.3.1 http://www.readynas.com/forum/viewtopic.php?t=63434 / kiokoman
0.3.2 http://www.readynas.com/forum/viewtopic.php?f=36&t=48440 / loustik
1. Package installation using PuTTy
1.1
apt-get update #to make sure your nas got the last packages
1.2
apt-get install -f
#fix broken/missing packages http://www.readynas.com/forum/viewtopic.php?t=63434
1.3
apt-get install nano libapache2-mod-php5 php5 php5-mysql php5-gd phpmyadmin
#install php & phpmyadmin
1.4 When ask, let phpmyadmin selfconfigure and type your admin password
2. setup Php
2.1 open /etc/frontview/apache/httpd.conf
one may use nano & Putty
nano /etc/frontview/apache/httpd.conf
ou use (like me) Filezilla via an SFTP account to edit and backup via your favorite tool (Notepad++ via windows for me)
2.2 after LoadModule addonhandler_module /frontview/lib/mod_addonhandler.so (ligne 22), add
LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
AddType application/x-httpd-php .php
PHPIniDir /etc/php5/apache2
2.3 At the end of the file, add
# Ajout Phpmyadmin
Alias /phpmyadmin /usr/share/phpmyadmin
<Directory /usr/share/phpmyadmin>
Options FollowSymLinks
DirectoryIndex index.php
<IfModule mod_php5.c>
php_flag magic_quotes_gpc Off
php_flag track_vars On
php_flag register_globals Off
php_value include_path .
</IfModule>
</Directory>
# Authorize for setup
<Directory /usr/share/phpmyadmin/setup>
<IfModule mod_authn_file.c>
AuthType Basic
AuthName "phpMyAdmin Setup"
AuthUserFile /etc/phpmyadmin/htpasswd.setup
</IfModule>
Require valid-user
</Directory>
# Disallow web access to directories that don't need it
<Directory /usr/share/phpmyadmin/libraries>
Order Deny,Allow
Deny from All
</Directory>
<Directory /usr/share/phpmyadmin/setup/lib>
Order Deny,Allow
Deny from All
</Directory>
3. restart apache using PuTTy so the modifications are activated
killall apache-ssl
apache-ssl -f /etc/frontview/apache/httpd.conf
4. Php is now running and phpmyadmin accessible via http://ip-readynas/phpmyadmin, but no user is defined
5. create a user (TOTO / PASSWORD_TOTO) via PuTTy
mysql -u root
GRANT ALL PRIVILEGES ON *.* TO 'TOTO'@'localhost' IDENTIFIED BY 'PASSWORD_TOTO' WITH GRANT OPTION;
6. Remember why you wanted to install phpmyadmin in the first place and start using it ;-)
ProSupport for Business
