DickfromHolland
Jan 21, 2020Aspirant
Mapping lost of Share from a specific Account (ReadyNAS DUO RN20200)
Hi, Initially a month ago I couldn’t access my NAS but that has been resolved by the SMBV1 check. But now, since a week ago I have a problem to access my Share with account **bleep**. I have se...
- Jan 22, 2020
I am somewhat puzzled by your description of the problem in the pdf. You have no Dick or Yvonne in your share list. Since you had accounts for both Dick and Yvonne on the NAS, I am thinking these two shares were actually private "home" shares - which don't show up in the public share list in frontview. If so, deleting Yvonne's account on the NAS would have destroyed the data in her share.
Anyway, I am thinking that your data was never in the public share \\NASDISK\Share, but instead it was in the private "home" share \\NASDICK\Dick.
What happens if you run the command prompt (type CMD into the windows search bar) and then type
net use * /delete /y net use t: \\NASDICK\Dick /user:dick dickspassword
using the real password of course? The first command terminates any open network sessions. The second attempts to mount the share as drive letter T.
If that fails, try using both commands again, but use the NAS IP address instead of the hostname.
Jan 22, 2020Guru - Experienced User
DickfromHolland
Jan 22, 2020Aspirant
Hi Stephen,
Many thanks for your help! I would say: "I'll vote you for President".
This command solved the problem and I'm now into my original home Share \\NASDICK\**bleep**
and have access again to all my files.
I'm really happy that you resolved my issue.
By the way. I secured all data from Yvonne before I deleted account Yvonne on the NAS.
Do I need to do something to get directly access to this home Share **bleep** when I reboot NAS and Windows 10?
Thanks,
**bleep**
