mdgm-ntgr
May 10, 2011NETGEAR Employee Retired
max concurrent Frontview backup jobs
It would be nice to have the ability to set a limit for the max concurrent Frontview backup jobs in Frontview. This could be required to be an integer in a specified range from 1 to whatever the max a...
fbmachines
May 10, 2011Guide
I thought about that option but each job can vary from <1 min to days depending on the amount of data and if it has to go over VPN with my mediocre upload rate.
So it would be a long drawn-out schedule and many files could drastically change, or be added between syncs. I guess I'm a bit paranoid about data loss (as if you couldn't already tell from my 9 NASs).
