sdchew
Aug 27, 2012Aspirant
Maxtor One Touch disappearing
Hi There, need some advice on a problem I'm facing with my USB Maxtor One Touch. Its is not USB powered and uses it own power adapter. I have a Maxtor One Touch (MOT) which is hooked up to the rea...
PapaBear1
Aug 28, 2012Apprentice
It sounds as if when the MOT is asleep the NAS can not detect it, which I can understand. Since it cannot detect it, it is not there to the system.
As an alternative, rather than powering down the NAS, consider using disk spin down. Some don't care for it, but I have one (NVX Pioneer) that is my backup unit. After the backups are finished, it spins down.
The only other alternative would be to disable the sleep mode on the MOT.
