j5races's avatar
j5races
Memory for NV+ v2?
What memory will the NV+ v2 accept? I have a 1gig stick in my old nv+, does the v1 and v2 share the same memory?
Will it accept 4 gig stick? if so does it help is more than 1 gb a waste?
Thanks
Jon
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Memory is soldered on the NV+ v2
    If you want upgradeable memory go with the Ultra/Pro. Do note that 3rd party memory upgrades are not supported.
  • soldered like surface mount? or maybe can be removed?
    Do i need more memory just to stream BD movies to a Dune player?
  • StephenB's avatar
    My much slower Duo V1 will stream BluRay quite happily to my media streamers. That only requires around 7-8 MBs/sec (56-60 mbits).
  • My slower NV+ V1 has 256 MB of RAM and will stream BDrips just fine. Even via 802.11N to my MB 2008.
ProSupport for Business
