PeterZaitsev
Aug 21, 2011Aspirant
Memory recommendation for ReadyNas Pro 6
I wanted to upgrade memory in my unit so I bought some recommended SODIMM memory which people were successfully using with ReadyNas Ultra 6. To my surprise unit I have does not use SoDIMM but rather ...
fbmachines
Aug 21, 2011Guide
PeterZaitsev wrote: Did anyone have any success fitting more memory in this unit and what vendor did you use ?
Overkill but here is a link to the 8GB (2x 4GB) sticks I'm using in one of my Pro-6.
viewtopic.php?p=276089#p276089
As PapaBear mention, memory upgrades aren't supported anymore and can cause data corruption. If you do decide to proceed, keep the original RAM for troubleshooting down the road to eliminate the RAM as the culprit. And make sure to run many memory tests before you put live data on it!
EDIT: See post below.
