CraftWorks's avatar
CraftWorks
Memory test on RN104: should I wait or should I worry?
Hello everybody,   I've decided to run a memory test on my good ol' ReadyNas 104 (I'd never done it before). Now, it's been runing for almost 12 hours, and nothing changed from the very first m...
  • Marc_V's avatar
    May 23, 2019
    Hi CraftWorks
    The test usually runs for a total of 4 hours before it gives a result, This might be a good time to try to check the logs. You can send it to us via PM using a download link.
    You may want to try running it once more but if it shows the same behavior, it might be time to contact Support if you still have the Hardware Warranty.
    Regards
ProSupport for Business
