dsnpevl
Feb 02, 2019Virtuoso
Message fields in some mails from "NETGEAR community <community@netgear.com>" are not filled in
Accasionally I receive notification mails from this Netgear Community. There seems to be a problem with the messages with the title "Did you get the answer you needed?". The variable fields ($.....) are not replaced with the actual message details and are still visible in the mail. See the image below.
The message also mentions that a "thanks for sharing" reply has been accepted as a solution. But I didn't accept any reply as a solution on this post. So the notification mail is incorrect, incomplete and confusing. Not sure why this happens, but I hope this can be fixed.
Example of faulty mail message
