bnrush's avatar
bnrush
Migrating data from ReadyNAS Duo to 214
My old ReadyNAS Duo is dead, sadly, though the redundant SATAs inside are fine.    I need to transfer the data from the old, but good SATA retreived from the old ReadyNas Duo and tranfer it to my h...
  • StephenB's avatar
    Nov 24, 2016
    You could also try installing r-linux for windows on the PC, and using the Sabrent adapter with disk 1 of the duo.
ProSupport for Business
