bnrush
Nov 23, 2016Aspirant
Migrating data from ReadyNAS Duo to 214
My old ReadyNAS Duo is dead, sadly, though the redundant SATAs inside are fine. I need to transfer the data from the old, but good SATA retreived from the old ReadyNas Duo and tranfer it to my h...
- Nov 24, 2016
You could also try installing r-linux for windows on the PC, and using the Sabrent adapter with disk 1 of the duo.
mdgm-ntgr
Nov 23, 2016NETGEAR Employee Retired
Nov 24, 2016Guru - Experienced User
- bnrushNov 25, 2016Aspirant
The filesystem, of course. I'm an idiot. Trying through a virtual linux box now. I'll post the results. Thanks for the help!
I'm trying an equivalent of R-Linux for OS X called PhotoRec.
When it asks me this, how do I know which disk is my NAS SATA (Linux Ext3/4 filesystem)? None of these look like the right capacity.
Select a media (use Arrow keys, then press Enter):
>Disk /dev/disk0 - 500 GB / 465 GiB (RO)
Disk /dev/rdisk0 - 500 GB / 465 GiB (RO)
Disk /dev/rdisk1 - 498 GB / 464 GiB (RO)
Thanks
Drive corrupted. Case closed.
