whartonw's avatar
Apr 26, 2021
Migrating disks backward from OS 6 to RAIDiator 4.2
I have a failed 424 chassis running OS6.  Can I move the disks to an old but operating Ultra 4, running RAIDiator 4.2 in order to retrieve the data on the 424?
Thanks.
  • Only if you first convert the Ultra to OS6.  It's not a one-way trip, so you can revert to OS4.2.x later, if needed.  Just use a drive that's not a part of either NAS's array to do the conversion process.
    The conversion process has been posted many times to the forum.  Do a search (I recommend Google rather than the forum's own search), and choose a recent posting from StephenB that explains the process.
    The reversion process is not as well documented, as few go that route.  But I can help if you get to that point.
    • StephenB's avatar
      Just out of curiosity - what happened to the RN424?  The warranty is 5 years, so if you are the original owner you might look into getting an RMA from paid support (via my.netgear.com).
      Netgear won't provide paid support on a converted NAS, so that is one consideration.  There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
      If you do decide to leave the Ultra running OS-6, then you should also consider increasing the RAM.  Your RN424 has 2 GB of RAM, your Ultra only has 1 GB.  Some folks who've done the conversion with just the stock memory have had problems with out-of-memory conditions.  The upgrade to 2 GB is inexpensive, and is simple to do. If you skip this step, be careful to only enabling services you need - e.g., don't enable file search, antivirus, etc.
      (Optionally) make sure the latest BIOS is installed before you do the conversion.  To do this you install  http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS.  Do this after you backup the NAS.  This isn't necessary, but if you so want to update the bios it is easiest to do it prior to conversion
      Basic instructions for the conversion itself are
      1. BACKUP, BACKUP, BACKUP
      2. Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
      3. Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
      4. After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
      5. Go through the setup process on the converted NAS
      6. Update the NAS to the current OS 6 (check for updates will work).
      7. Restore files from the backup.
      Of course if you don't care about the data on the Ultra, you can skip steps 1 and 7.
      If you want to go back to 4.2.31 later on, you can remove the Ultra disks (labeling by slot), and install a temporary disk.  Then set up the NAS on 4.2.31, and execute the conversion.  You will need to reverse the conversion afterwards, so you will need the temporary disk again when you do that.
      Post conversion, you can power down the NAS, and migrate your disks (preserving slot order).  Then just power up, and the system should boot on OS-6, with your data and apps intact.
      • whartonw's avatar
        whartonw
        Guide
        Since you asked, StephenB...the short answer is that I don't know yet.
        Spontaneously, a few weeks ago, all the wired connections in my LAN were completely disconnected.  Many, many hours of trail-and-error troubleshooting later, I determined that the 424 connected to the Orbi router was the issue.  I can't imagine how this is possible, but then all I know about the inner workings of LANs would not take up a lot of disk space.  I got no usable help from the Orbi forum, (although a lot of attempts and commisation).
        Anyway, I am rapidly losing faith in Netgear over usability issues and the lack of sortware updating (I've got an Ultra that hums along like a Swiss watch, but needs software patches for network communication security so Windows will talk to it).  I have been researching a replacment for the 424.  Once I get the 424 off the my network, I plan to connect it directly to a computer via the network port and see if I can see if I can figure what's going on.
        I don't mind paying Netgear for repairs, so that's probably what i'll do.  It's a quality piece of hardware.
        I have the data on the 424 backed up, but it's a cloud backup, so if I could just put the disks into another chassis to retrieve the data, it would be quicker.
        Probably more than you wanted to know, but I appreciate your interest.
    • whartonw's avatar
      whartonw
      Guide
      Thanks, Sandshark.
      I appreciate your reply.  If the 424 is beyond resusciaition, I think that's what I'll do.
      w
ProSupport for Business
