Mstead
Sep 26, 2018Follower
Migrating drives between ReadyNAS units
Hoping that someone will be able to help!
I have a failed ReadyNAS V1 (RND4000); the power supply has failed. There are 4 disks in the unit that were default formatted to RAIDX. I’m wanting to move the disks to another unit (RND10400). Can I do this and keep the data? If so, how?
Any help would be very much appreciated.
Mstead wrote:
Can I do this and keep the data?No. The platform is very different, and that won't work.
You can ask support to temporarily mount your disks in the new NAS so you can offload the data somewhere else. They often charge for that. https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
If you can connect the disks to a PC you could use R-Studio software to access the files. https://www.r-studio.com/free-linux-recovery/Download.shtml If the PC is running linux, you can also mount the array manually.
- progers1000Aspirant
I spoke with support and they said this would work. I put the old drives in the new device and it has been booting for 15 minutes. Thoughts?
Did you tell support that you'd tried to do an OS reinstall with the migrated disks in place?
