Mstead
Sep 26, 2018Follower
Migrating drives between ReadyNAS units
Hoping that someone will be able to help! I have a failed ReadyNAS V1 (RND4000); the power supply has failed. There are 4 disks in the unit that were default formatted to RAIDX. I’m wanting to move t...
Sep 26, 2018Guru - Experienced User
Mstead wrote:
Can I do this and keep the data?
No. The platform is very different, and that won't work.
You can ask support to temporarily mount your disks in the new NAS so you can offload the data somewhere else. They often charge for that. https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
If you can connect the disks to a PC you could use R-Studio software to access the files. https://www.r-studio.com/free-linux-recovery/Download.shtml If the PC is running linux, you can also mount the array manually.
progers1000
Oct 25, 2018Aspirant
I spoke with support and they said this would work. I put the old drives in the new device and it has been booting for 15 minutes. Thoughts?
- StephenBOct 25, 2018Guru - Experienced User
Did you tell support that you'd tried to do an OS reinstall with the migrated disks in place?
- progers1000Oct 26, 2018Aspirant
Sorry let me give you a little more details and let me know if this is the wrong thread. I have an older ReadyNAS. It recently failed and won't power-up. I think there is a problem with the power supply. I want to know if I can buy a new one and move the disks from the old device into the new device. Support provided me with a model that would work as long as I put the drive in the same order. I did that, turned it on but it just said booting for 15 minutes. I stopped it because I was concerned it was going to format the disks. I don't want to lose the data on the existing drives.
- StephenBOct 27, 2018Guru - Experienced User
Let's stick with one thread: https://community.netgear.com/t5/Using-your-ReadyNAS/Upgrading-to-ReadyNAS-214/m-p/1657479
Generally speaking, if you have a support case it is probably best to work directly with paid support, to prevent confusion.
