Blacktimor
Apr 27, 2019Aspirant
Migration of existing disks to a new NAS box
My NAS RN21200 was replaced under warranty. I have 2 x 6TB disks which are mirrored and contain important data. When I received my new NAS r...
JohnCM_S
Apr 27, 2019NETGEAR Employee Retired
Hi Blacktimor,
If the replacement unit is just of the same model, you can just insert the disks in the same order on that unit. No data should be lost when you do that.
- BlacktimorApr 27, 2019Aspirant
Hi, the only problem is that I do not know the order of removal of the disks. So there is a 50% chance of getting it right and 50% chance of getting it wrong. What happens if I insert them in the wrong order?
Terry
- Retired_MemberApr 27, 2019
Hi Blacktimor, you wrote "the only problem is that I do not know the order of removal of the disks."
Should you still have a logfile you downloaded from of the old box you could look into disk_info.log to see which disk was in which bay. You would see that by comparing the serial number on each disk with that what is listed in the logfile.
Kind regards
- BlacktimorApr 28, 2019Aspirant
I have dowloaded the log file for future reference so thanks for that information. Could you tell me where the log file has been downloded to on a Windows 10 box.
Terry
