Starco
Feb 25, 2012Follower
Move disks from NV+ to Duo?
My friend has an NV+ which won't start after a lightning storm last month. Can I move the two 500 GB disks from the NV+ into my Duo so we can access the data? Both ReadyNAS' are Sparc-based and run 4....
mdgm-ntgr
Feb 25, 2012NETGEAR Employee Retired
Yes. Provided the disks are fine and there were only two disks in the NV+ that should work. See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
