PelleS
Oct 28, 2017Guide
Move disks from ReadyNAS NV+ to ReadyNAS 214
My ReadyNAS NV+ is not starting up after power failure, even though I have an UPS with battery back-up. Suspect it might be the power pack? Hopefully my disks (4*2 TB) are OK, running X-RAID. Can I m...
- Nov 06, 2017
Contacted Netgear support, they were very helpful. They offered to send me a new PSU and after replacing my old one I'm up and running again! Very good support, Netgear:smileyhappy:
PelleS
Nov 08, 2017Guide
Hi Decker72,
I live in Sweden and contacted the swedish support (had to sit in the phone for quite a while...). They were very accomodating and recommended me to try a new/refurbished PSU, which they sent me.
There are quite a few topics on both the Netgear community and YouTube about the PSU on ReadyNAS NV+, indicating that it's not an uncommon problem. You can find some helpful tips there about getting a new PSU and changing it yourself, if your support aren't willing to help. From what I gather it doesn't seem that hard to do :smileyhappy:.
Good luck!
Decker72
Nov 09, 2017Aspirant
Thanks for the prompt reply. I think I may have been reading some of the same threads. I've pulled the old supply out and it sure has a burnt out smell to. I had an old desktop PC in the cupboard, so pulled the power supply, re-wired the pins as per some of the instructions on the site, and managed to get it to start up without any disks in (although frankenstein's monster would fall in love with it as it looks now :) ). Off to get a large capacity backup disk tomorrow, drop the disks in, hope it comes up in a friendly manner and rip all the contents off ASAP. Then if she seems to be happy running on the new power supply, I've found a couple of the mini-ITX psus on ebay that will fit the bill. About A$80 to get a new lease on life is reasonable to me, but it's backing up regularly for me from now on :)
Thanks again,
Brett.
