cyon
Sep 07, 2012Aspirant
Moved ReadyNAS NV+ & Won't Power Up
I moved my ReadyNAS NV+ A201-75xx for a 3 hour drive to my new location. When setting up, I pressed the power button and nothing at all. No leds, no fan, no nothing. - Yes, it's plugged in :) - T...
cyon
Sep 12, 2012Aspirant
No it doesn't fit. However, it's installed and the case is entirely put together so it worked out perfect for me. I mean it just sits there %99.9 of the time, but, still easy to move if needed. I've considered fabricating a little support bracket to hold the psu in place.
