cyon
Sep 07, 2012Aspirant
Moved ReadyNAS NV+ & Won't Power Up
I moved my ReadyNAS NV+ A201-75xx for a 3 hour drive to my new location. When setting up, I pressed the power button and nothing at all. No leds, no fan, no nothing. - Yes, it's plugged in :) - T...
mdgm-ntgr
Sep 12, 2012NETGEAR Employee Retired
Warranty was 5 years on new purchases from August 21, 2007 to sometime in 2009 (I think). Is the unit registered at my.netgear.com? Check the expiry date there and if it's still under warranty you should be able to at least ask for a replacement PSU under warranty (though they may wish to replace the entire unit).
