KJ
Feb 05, 2007Aspirant
MRTG config info
Since I have been struggling to figure this out, I thought I would share my mrtg.cfg file set up to monitor eth0 on our ReadyNAS NV+: ### Global Config Options # to get bits instead of bytes and...
Piggelmee
Nov 25, 2007Aspirant
The SNMP targets have been changed in the new RAIDiator v4 firmware.
This is the new ReadyNAS MIB: READYNAS-MIB.txt (unable to post the link due to the spamfilter, the link was posted in the Feedback forum)
I succesfully monitored the traffic, fanspeed, temp and diskspace with MTRG as described in this thread, but since I upgraded to v4 this doesn't work anymore.
I already found the new target for the network traffic:
Firmware v3: Target[raid1_eth]: 3:public@192.168.0.2
Firmware v4: Target[raid1_eth]: 2:public@192.168.0.2
How can I determine the MRTG Target OID's for temp, fan and volume from the new MIB? Has anyone figured this out yet? It seems that the individual disktemp can be monitored now as well, but again: how do you figure out the new targets?
Thanks and regards,
Paul
Thanks and regards,
Paul
