KJ
Feb 05, 2007Aspirant
MRTG config info
Since I have been struggling to figure this out, I thought I would share my mrtg.cfg file set up to monitor eth0 on our ReadyNAS NV+: ### Global Config Options # to get bits instead of bytes and...
Piggelmee
Dec 07, 2007Aspirant
saxofon wrote: snmpwalk is your friend :idea:
I would appreciate if you could be a little bit more comprehensive. I already played around with snmpwalk and snmpget for a while, but it still doesn't make much sense. If I try this command:
snmpwalk -M readynas.mib -v 1 -c public readynas.mydomain
the output is a huge list of OID's and their values. But how do I tell which OID represents what?
Thanks in advance for your help!
