KJ's avatar
KJ
MRTG config info
Since I have been struggling to figure this out, I thought I would share my mrtg.cfg file set up to monitor eth0 on our ReadyNAS NV+:
### Global Config Options
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
LoadMIBs: /home/username/www/mrtg/INFRANT.MIB
WorkDir: /home/username/www/mrtg
Options[_]: bits, growright
# System: ReadyNAS
# Description: Linux ReadyNAS 2.4.20-3.00c1.0 Wed Nov 29 15:20:42 PST 2006 sparc
# Contact: root
# Location: Unknown
Target[nas]: 3:public@192.168.1.17:
SetEnv[nas]: MRTG_INT_IP="" MRTG_INT_DESCR="public"
MaxBytes1[nas]: 1000000000
MaxBytes2[nas]: 1000000000
Title[nas]: Traffic Analysis for ReadyNAS
PageTop[nas]: <H1>Traffic Analysis for ReadyNAS at 192.168.1.17</H1>
I couple of FYIs here:
The MIB might not even be necessary for the network statistics, but you can download it from the Infrant website here:
http://www.infrant.com/download/INFRANT-MIB.txt
This was on a NetBSD box, so your path to the username directory may look different (or wherever you decide to put it). You'll have to fill in the correct path/username. The IP address will be different as well.
That all being posted... does anyone know how to set up a config to show the volume statistics? (used, free, total)
Thanks!
KJ
  • I can't seem to find out how to get the Fan RPM, Temp and so on....I can find HDD info but not the critical temperature and fan rpm!
ProSupport for Business
