sisao
Jul 02, 2013Aspirant
Multiple Disk Failures - Next?
Hi gents, my setup is ReadyNAS Duo SPARC with 2 disks WD20EARS in X-Raid. Latest RAIDiator. Channel 2 reported SATA errors and disk failures so i replaced it with another disk which is providing t...
sisao
Hi thanks,
nope...no test on the second disk yet...the test on the first already concluded with no problems reported. RAIDaitor is 4.1.10 SPARC.
Would you reccomend mounting two different drives on the DUO? Also, WD RED 2TB is like 85€ plus 80€ of the new WD20EARS just bought is more or less the price i payed for the DUO in the first place :D
I'll check the second disk as well, potentially remounting the old one also!
Thanks.
Thanks.
