sharpycl
Feb 19, 2016Aspirant
My ReadyNAS does not show up as a Network Computer
Can someone tell me if the ReadyNAS is supposed to show up as a Network Computer? I can mount it as a Network Drive but no matter what setting I have tried it will not show up as a Network attached c...
- Feb 20, 2016
Please have a quick (if you can) look at https://community.netgear.com/t5/Using-your-ReadyNAS/windows-not-showing-ReadyNAS-name-in-network/m-p/945867.
Although the solution MAY not apply to you, there are lots of pointers and ideas in it.
I am not saying it will give you the solution (although it might), but we don't want to reinvent the wheel again, do we?
Regards and good luck on your quest.
Good night.
Feb 19, 2016Guru - Experienced User
With Win7 and Win10, all mine show up under both the "computer" and the "storage" categories. The ones with DLNA enabled show up again as "media storage".
This is frankly hit-or-miss. A poster this morning had trouble getting them to show up in his network list, but power-cycling his switch resolved it. I created shortcuts on my wife's laptop, just to make sure she had a consistent way to get to the shares she uses.
- sharpyclFeb 19, 2016Aspirant
I'm on my second day of owning the ReadyNAS and I just tried another power cycle but still it's a no show under network computers. The mounted drives work great but I'd love to also have the network places working too. I wonder if an update will fix this in the future? I'll cross my fingers :)
Thanks so much StephenB.
- BaJohnFeb 20, 2016Virtuoso
Just to add my 2 pennith ...
With Win7 and Win10, my NAS shows up ONLY under the "storage" category.
I do not believe that I have ever had it show up under the "computer" category.
I do however have a share from the NAS attached as the A: drive on my PC.
If you say which OS you are running, others MAY be able to give a more definitive answer.
- sharpyclFeb 20, 2016Aspirant
Hi BaJohn,
Sorry I guess I should've mentioned that I am currently running Windows 10.
Thanks for any help you might be able to give.
- BaJohnFeb 24, 2016Virtuoso
sharpycl wrote:.................... The mounted drives work great .....................
Just to satisy my curiosity, as you have a similar setup to myself.
Do your mounted LAN connected drives stay mounted during a restart?
I spent ages trying to fix this, and it turns out (apparently) that with a fast loading PC, it tries to access the drives BEFORE the Internet is setup.
This causes the drives to appear 'not connected' in file explorer, until you click on them. So for a while I used to start my PC and then click on the drives every single startup. I get so 'pi....f' that I wrote a batch file to run automatically that does the work for me and lets me know if there is a problem straightaway.
So, if your system drive is an SSD (then being super fast to load), do you have that problem?
Regards
- StephenBFeb 24, 2016Guru - Experienced User
I do have an SSD system disk, and my win10 mapped drives stay mapped. (I've occassionally seen them dropped, but clicking on the them restores them).
With Win-7 there is a registry setting change that is sometimes needed - I'm not sure if it carries over to Win-10. https://technet.microsoft.com/en-us/library/ee844140(v=ws.10).aspx
