Chris_Boston
Jun 28, 2012Aspirant
My ReadyNAS Story . . .
Day 1... After a month going back and forth between manufacturers, and then finally between the Pro 2, 4, and 6, I order the 6 from Amazon on Tuesday along with two Seagate Barracuda Green 2TB SATA...
Chris_Boston
Jul 02, 2012Aspirant
mdgm wrote: What's the suffix on the drive model and what firmware version is on the drives. You can check under Status > Health in Frontview and clicking on the SMART+ button. Depending on which one you have there may be a drive firmware update available shortly which you should install.
Yeah, I followed that drama over in the other thread - I'm hoping for the best, I have a friend running these drives for a few months without issue. Both drives are: ST2000DL003-9VT166 with FW: CC45.
mdgm wrote: There is a new UI in development. No ETA on it coming to x86 though. You can however see it in the Duo/NV+ v2 manuals: http://www.readynas.com/docs
Wow, much better! Looking forward to that update.
