Chris_Boston
Jun 28, 2012Aspirant
My ReadyNAS Story . . .
Day 1... After a month going back and forth between manufacturers, and then finally between the Pro 2, 4, and 6, I order the 6 from Amazon on Tuesday along with two Seagate Barracuda Green 2TB SATA...
PapaBear1
Oct 24, 2012Apprentice
I will certainly agree that you should open a ticket. I wish you had posted this several months back, for at that time you could certainly use the phone support (free for first 90 days after purchase), however you still get free on line support. When I saw your first post about the freezing, my first thought was that you had possibly enabled disk spin down, for there is a delay while the drives spin up, but no resync takes place in that situation.
If you don't have any data at risk, it would be interesting, if you had some spare drives, to see if the Pro 6 reacts the same way with drives other than those Seagate drives. From the drama, as you described it, it seems to be similar to the reaction they were seeing.
