jmessina
Apr 07, 2022Aspirant
N600 as wireless NAS only
I have an old N600 (WNDR3400V2) router laying around unused, and I'd like to know if I can use it as a wireless NAS w/its USB drive connection. I'd like to have the N600 connect up to my existing ...
Apr 08, 2022Guru - Experienced User
jmessina wrote:
That doesn't sound quite like what I was after.
The other option is connect everything on your home network to the N600 (using its wifi and ethernet LAN). Then connect the WAN port of the N600 to a LAN port of the ISP router. But the N600 is really old (10 years I think), and your ISP router is likely much faster.
Back-to-back routing works ok, but you do need to do a couple of extra steps when port forwarding.
jmessina
Apr 08, 2022Aspirant
My current setup is a cable modem + tplink M5 mesh network.
The M5 does have another ethernet port available, but I was hoping for a way to attach the N600 to it as just a NAS while having everything else use the M5 mesh, and still have the old "\\readyshare" connection to the USB storage on the N600.
